Fairing space
Old 09-18-2018, 06:19 PM
Ron D 33's Avatar
Ron D 33
Ron D 33 is offline
Originally Posted by SDrider
Thanks for the info guys
rob, if youre only using it as a 4 channel how come did you decide on that one and not get a higher juiced 4 channel and a dsp to cover both amps? Btw, It looks great and im sure sounds just as good.
I've had other 4-channel amps in there. To me that amp puts out a good amount of power and very efficient compared to some high power 4 channels I've used. Having 8 channels also opens up the door for more opportunities down the road for speaker choices. In my opinion having the DSP built into the amp cuts down on the noise floor and it has a cleaner sound to me too.
Old 09-18-2018, 08:24 PM
Babyboy's Avatar
Babyboy
Babyboy is offline
Im down to PRVs in fairing in BT speaker pods. B3 horns and then vo6x9s in the lids(possibly horns in future). Is it possible to get an arc psm, focal sport(PRVs and VOs), and say an nvx(horns) under the hood of a 14 street glide or is the second amp going in a bag? Or would i be better off with a 6 channel amp and a dsp in the fairing?
If you get creative you can mount a few amps depending on size in the fairing of a Rushmore batwing.
If you are using the speaker Podsyou can get 3 amps in the fairing with a possible 4 depending on the size amp that is on the amp tray.
Again it all depends on the size of the amp.
Old 09-19-2018, 07:33 AM
MMXIWG's Avatar
MMXIWG
MMXIWG is offline
Ron, do you capability to adjust via Bluetooth on that VXI or do you have to hook up a laptop or tablet via USB?
Old 09-19-2018, 08:16 AM
Ron D 33's Avatar
Ron D 33
Ron D 33 is offline
You can do BT with the controller for $100. I tune wirelessy with my tablet and don't use my phone or laptop. The phone is a little small and difficult, unless it's just small adjustments, and a wired laptop is kind of a pain and after having wireless capabilities.
Old 09-19-2018, 10:14 AM
JMC22's Avatar
JMC22
JMC22 is offline
Ron: Did you have to do any mods to get the amp to fit on the the JM Amp tray?
Clean set-up, you got me thinking of replacing my Focal Sport
Old 09-19-2018, 03:46 PM
Ron D 33's Avatar
Ron D 33
Ron D 33 is offline
Only thing you have to do is cut the glove box mount tab. Don't use the J&M top tray and use Velcro around the side of the amp and bottom back side. Push it up on the lip in the back. It will stick in there nicely and doesn't move. It actually fits better than the 600/6, it's a little wider but not as deep which is better. I ran the Sport for a few months too. It's a good amp, but I won't ever run it again after using the VX series.
pglider
Audio Systems
09-04-2017 01:26 PM
flcusat
Audio Systems
07-01-2017 10:56 AM
509Rider
Audio Systems
05-18-2016 07:54 PM
ckef_koran
Audio Systems
11-09-2013 07:23 AM
DGlide04
10-10-2012 07:48 PM
Quick Reply: Fairing space
