Whirring Noise From Speakers...
Originally Posted by roussfam
Found amp trigger wire on the HU harness. Amp is only powered up now when HU is on. Noise is gone. Thanks guys!
Jerry m
Jerry m
So turn gains all the way down, set HU volume at 3/4, increase gains slowly until u even think ur getting distortion. Then back the gains off just a touch.
3/4 HU volume is now your maximum volume level and you should NEVER exceed it.
Make sure do a final tune w the engine running as u will have higher voltage to contend with during the tuning process.
T
Playing around with my meter, discovered that I didn't blow a Kappa. Bad connection at the terminal screws. If I insert the probes, tighten the screws, then move the probes around, I get a circuit.
I'll wait until Monday to see if the Canadian supplier will do anything for me. If not, out comes the dremel for a little Surgery
I called
