Anyone running a DSP with the new Sony double din?
I had installed a Mini DSP with my factory head unit before my J&M amp, but eliminated it with my Sony install. It was like a little magic black box!
The J&M has a built in DSP in the amp and although it does not have the option to adjust PEQ at the Line in level, I don't need it with the Sony since it's a flat input. I only had it to smooth out the EQ at the Factory HU output. The J&M DSP does the same PEQ adjustments before it is amplified ad the Mini DSP.
Smitty
Smitty
I would try both ways. If you can achieve the sound you want without it, then there is a piece that doesn't need to be in line and can be sold. If you use it and can achieve a better sound to your liking by using it, then why not. You bought both the sony and dsp to achieve a better SQ to begin with.
