This is what came with my amp, while it sounds good to me I can't help but think I can get more out of it,I set gains with a smd dd1 but barely get to 10 o'clock on the gains and the smd shows distortion. Using 1000hz -5db
how high you raise the gain is relative to the input voltage. You can have an amp place far requires almost no gain adjustment if it has sufficient input voltage.
Headunit is a Sony mex gs810, 5v preouts, showed zero distortion uup to 48 of 50 clicks,set the amp with volume of 44, and eq flat, loudness and all that off, bike running.
if you read the online "manual" for that amp, it also states that only the rear channel is bridgeable, yet my birthsheet shows it was tested to 356 x 2.. Ill take my chances and bridge 4 to 2 cuz its small, powerful and clean
