Focal ES165KX2 on 2015 Road Glide Special
The cut is not that big, you just have to mount the speaker upside down on the speaker hole to make sure your speaker lip does indeed fit perfectly on the hole, flip the speaker to normal orientation and mockup fit the speaker on the hole, you will then be able to identify where exactly the magnet hit the wall and make markings where to cut. I cut mine with dremel, very easy 5 minutes job to do the cut, it was about 5 x 3 square hole. I did not take any pictures when cutting but I can snap a few pictures of the finished job, I'll post it up in an hour.
wevsspot (08-23-2018)
wevsspot
Audio Systems
16
10-03-2018 01:30 AM
wheelman38
05-04-2018 01:10 PM
Pork-Chop
06-15-2009 09:54 AM
