playing music
I copied this from another thread:
“This is straight out of the HD Owners Manual:
Accessory Mode
See Hand Controls and Switches . With the key fob present, press and hold the trigger switch. The instruments and accessory circuit are powered. The headlamp and turn signal lamps remain off. While in accessory mode, the instruments display the fuel gauge and odometer functions. The headlamp can be activated by pressing the headlamp flash to pass switch.
To turn the motorcycle back off, press and hold the trigger switch.
Do not leave the motorcycle in accessory mode for an extended time. This can discharge the battery. If the vehicle is left in accessory mode for two hours, the motorcycle automatically shuts off to prevent complete battery discharge. To resume accessory mode, press and hold the trigger switch again."
Accessory Mode
