Sony xav 5000 quick wiring question
NEVERMIND..FOUND ANSWER-- Sony xav 5000 quick wiring question
Installed my new sony 5000. I had question for hand control wiring.
i installed the Scoshe handlebar control relay. There is a set of wires .. Key1,Key2 and ground alond with the 3.5mm plug to connect..
Do the wires need used?
I didnt hook them up and things are working fine. Just couldnt find anywhere that explains these wires.
I ssee all i have to do for parking wire is to twist together with ground wire to shut of the safety feature. So my only question remaining is the Key1,Key2 and ground for handlebar relay.
Probably simple answer, but i cant find it.
1986FXST
06-04-2008 03:31 PM
