Need help!!
Need help!!
2018 Street glide with 6.5 infotainment system.... I installed a Cerwin Vega B52 amp with Hertz HCX 6.5 in the fairing. i used the biketronics bt355 line leveler... heres my problem... it sound like it under water and muffled.. not clear at all! do i need to have my radio flashed? if so what flash?.. Amp is set on HP as recommended along with the crossover about 80hz
Then go back and triple check again!!!
No flash is required with the BT355 and a 2 speaker setup. But a radio reset never hurts.
T
How do you have the speakers mounted? Are they mounted like the stock speakers that came out and using stock grills? If so, then the rubber for the woofer is in contact with the grill and that will cause it to sound muffled. You just may not have a wiring problem. Look down at the top of the pod and you can see if the rubber is touching the grill or not.
