What to expect
All personal preferences and stereo v mono is just another detail that each individual must decide on when they plan their setups. Stereo is a high priority for my personal preference list. How is your personal genre / music list produced and intended to be played?
Bridging in general is another detail that must be considered for your individual priority matrix as those that ride first and hit a parking lot bash once or twice a year will probably consider storage space to be more sacred thus will choose Watts per channel aka watts per square inch of amp space over more amps to potentially make up for the lost channel footprint. Some will also choose a Watts over a "warmer" amp and plan their build around speakers that are inherently warm versus bright. Others will select certain speakers / speaker specs to meet an objective and are inclined to compliment such speakers with warmer amps.
Lots of moving parts in sled audio. No two builds are exactly the same. No two priority lists are the same either. But a shixload of things to consider individually vs blindly following.
T
T
WVJarhead (08-03-2018)
With only the four 4ohm speakers currently in my setup, would there be a difference between the 2ohm and 4ohm amp? The only amp specs I could find were on a sales website (network restrictions won't allow access to SD website) and I thought the 2ohm amp was good for 61W x 4 into four ohms and the 4ohm amp was good for 110W x 4 into four ohms. I could be misstaken-wouldn't be the first time.
T
T
Definitely plan out your system, then work off your plan. Measure twice cut once. Try to look forward as much as possible. It's every ingredient that makes the end result better. Can not stress this enough.
Respectfully I disagree.
There are many situations where mono is better than stereo, same goes for running bridged, running 8 ohm speakers, configuring some in stereo others in mono, etc. Hence why a "sound stage" has highs, mids, and lows, and different frequency ranges tend to require different strategies, for example how to get the best sound of a sub is likely different than getting the best sound out of a compression driver. That's why putting things into a box and saying "this is the standard" is tough to do, even more so on bikes where traditionally audio practices don't always translate over. Personally I would never wire the left side and right side together if we're talking a 6.5 and a 6X9 when you have a DSP available to tune each speaker differently to get the best - highs, mids, lows, independently.
