6x9 Drilled hole strategy
Yes, you do loose some sound at speed, but with everything else I have still makes for clear tunes.
MMATS 601.4
VO B3 Horns
Lowers
MMATs 601.4
Tour Pak
Polk MM652
Bags
VO 6x9s
AMPS
Diamond Audio 4v2 Pushing Fairing and lowers
SD 800.4 Pushing Tour Pak and Bags
No secrets other than Sony Head unit XAV AX100 and tuned by ear with multiple songs.
I can listen to Rock, Country, Hick-Hop with out even messing with my settings.
Sounds dang good sir.
Fairing
MMATS 601.4
VO B3 Horns
Lowers
MMATs 601.4
Tour Pak
Polk MM652
Bags
VO 6x9s
AMPS
MMATS 601.4
VO B3 Horns
Lowers
MMATs 601.4
Tour Pak
Polk MM652
Bags
VO 6x9s
AMPS
Solid plans produce solid results. Based on your comment about the H/U I'm assuming you feel that particular H/U is giving you similar tuning capability as a stand alone DSP? My question is not a challenge, it's to learn.
I really appreciate guys that think outside the box and have the patience to see things through.
Zach
Zach
Zach
Zach
Just easier to make it sound good. Hell I am still running my fairing and horns in parallel.
I do have a DSR1 in my drawer waiting on winter for a complete re-wire and change things up for next years Meet and Greet.
