2016 flhxs speaker upgrade
howdy folks
I have a 2016 flhxse cvo street glide and am tired of the stock boom2 speakers giving up the ghost I would prefer to go Rockford fosgate I was looking at the tms65 in front and the t1572 5x7 in the rear
would these be a direct drop in ?
I understand I will have to wire both positive and negative connections together to the speakers as they only have a single connection and a built in crossover
thanks for your time and opinions
howdy folks
if im reading the wiring scematics correctly the tweeter and woofer both get their signal from the same amp not from separate amps, from what I can find the amp has a built in crossover to filter the signals from the woofer/tweeter.
and yes it has the factory boom 2 setup.
To do the audio upgrade correctly you will have to remove both the BOOM amp and speakers and replace them with aftermarket equipment. At this time there are not any aftermarket speakers worth while to consider for swapping the proprietary only boom speakers.
Sorry to rain on your parade about the boom junk but just to keep you from getting to far off track and wasting your time trying to hunt down a ghost that dont exists.
