How many speakers can be run off a Arc 600.4?
Id really rather not have to replace the amp again. How about if I pulled the Arc 602s and replaced them with the Polk MMs that I have? Right now I'm planning to run the Polk MM692s in the lids. I mean that I like the sound that I'm getting from the Arc 602s, I'm just not getting enough. And I cant tell that I'm getting anything from the BT Titan 2s in the lowers.
If you plan on selling the Arc 602’s. Hit me up. lol. Those speakers perform best with 150-200 watts each. 175 would be perfect!! So if you like the Motos and want to keep em. You need to sell the Arc and get two new amps that produce the power you need. No way around it.
For now, I'm happy. The DB Drive Moto's are plenty loud and sound good (to me). If I was going to add lowers, I would keep the Arc and run the fairing and lowers of that amp and maybe go with a JL MX280/4 or maybe a NVX MVPA4 (Don't know a lot about this amp, but it's small and the specs look good) bridged for the lids. Also their is suppose to be some new super amp coming out that is suppose to fit in fairing and be 150/8 and retail for $400-$450. If it ever happens or is as good as the claim, we will see.
You might also want to try your DB Drive Moto's in the fairing first seeing how you already have them before you do anything else.
He stated somewhere that he also had a set of the DB WDX6Moto's he was going to try and put in the lowers. Figured he might as well try them in fairing before he did anything else and see how he liked them there.
