Rushmore Road Glide & PN4.1000D
Old 06-04-2018, 08:55 AM
hernaa02's Avatar
hernaa02
hernaa02 is offline
Default Rushmore Road Glide & PN4.1000D
Looking for pics from anyone running the Soundstream PN4.1000D in the fairing of a Rushmore Road Glide. Any tips on fitmemt will also be appreciated. Thank you.
Old 06-04-2018, 10:16 AM
Outkast6991's Avatar
Outkast6991
Outkast6991 is offline
the length is gonna be tough. maybe under the radio on an angle assuming you don't have horns mounted there. I'd mock up a block of wood and see before you buy it
Old 06-04-2018, 10:54 AM
hernaa02's Avatar
hernaa02
hernaa02 is offline
Gotcha. Good idea on the block of wood. Thanks
Old 06-04-2018, 11:42 AM
haze324's Avatar
haze324
haze324 is offline
It fits tight. You need to cut the tabs that hold the plugs on top of headlight and then route wires under the radio or to the sides. The amp takes up the entire area of the top of the headlight. It's tight...but it fits.
Old 06-04-2018, 11:57 AM
hernaa02's Avatar
hernaa02
hernaa02 is offline
Hey thanks bro. Does fit side to side or front to back? I hope that makes sense. Length wise, it’s 10.25”
Old 06-04-2018, 12:25 PM
shogunbikes's Avatar
shogunbikes
shogunbikes is offline
It fits side to side on top of the headlight and as Haze stated you will have to cut the plastic wire holders
Old 06-04-2018, 01:12 PM
hernaa02's Avatar
hernaa02
hernaa02 is offline
Perfect. Thank you
Old 06-05-2018, 08:42 PM
ScreaminChicano's Avatar
ScreaminChicano
ScreaminChicano is offline
6th Gear
I got one, it seems too wide. I'm also gonna be using a custom amp rack. I'm thinking about getting a arc or diamond amp.
Old 06-05-2018, 09:51 PM
madaba's Avatar
madaba
madaba is offline
Is that the XELCustoms tray?
Old 06-05-2018, 09:55 PM
ScreaminChicano
6th Gear
Yea it is
Quick Reply: Rushmore Road Glide & PN4.1000D
