Hoppe Quadzilla speaker upgrade without an amp?
Old 05-30-2018, 08:41 AM
trigger1911's Avatar
trigger1911
trigger1911 is offline
Default Hoppe Quadzilla speaker upgrade without an amp?
To put it bluntly, the sound out of my Hoppe Quadzilla sucks! My friend has a Street Glide and updated his system and gets amazingly clear sound out of his 2 fairing speakers. All I get from my Hoppe is
treble and the bass distorts if you turn it up. I dont know much about electronics but here is what I am after and what I have to work with. There is no room for an amp in the fairing and I wont put one in the saddlebags or enough room for bigger speakers inside the fairing. so I need to stick with 5 inch speakers and no amp. I exhausted the search on here so here is what I am after.
The following numbers are another language to me. The stereo I have is a Jensen JHD3630BT with built-in MOSFET amplifier (22 watts RMS/45 peak x 4 channels) and the speakers are Jensen 5" 2-way motorcycle speakers 35W RMS, 75W Max 4 Ohms(Model number JXHD50HPB).
If I could get away with a new set of 5 inch speakers that would be perfect but I dont expect miracles, after all you can only get so much sound out of small speakers. Thanks in advance!
Old 05-30-2018, 11:55 PM
marshallb's Avatar
marshallb
marshallb is offline
Trigger1911 that looks like the exact same as my wife's Hoppe fairing. I had NO trouble putting 4 Kappa 5.25" and a CV B54 in the fairing. I had to ditch the plastic "rain shield" but it can be replaced with a plastic table place mat. It only took me about 4-5 hrs to do the whole job.
trigger1911 (04-21-2019)
KnarleyHarley
Audio Systems
07-03-2018 02:05 AM
the4thgearkid
08-31-2014 01:05 PM
2006ultra
Touring Parts
02-25-2012 10:27 AM
m50
03-01-2011 06:49 PM
blown alcohol
09-23-2009 03:09 PM
Quick Reply: Hoppe Quadzilla speaker upgrade without an amp?
