Install Help...Pics/Diagrams
Old 05-25-2018, 09:34 AM
jory434's Avatar
jory434
jory434 is offline
delete
Old 05-26-2018, 10:52 AM
Blue Tick's Avatar
Blue Tick
Blue Tick is offline
Will the MM’s or CX’s be a direct pak pod drop in?
Old 05-27-2018, 07:16 AM
Dsm Limited's Avatar
Dsm Limited
Dsm Limited is offline
Received 9,598 Likes on 3,246 Posts
It's my understanding that the polks will go in a Rushmore tp by rotating them. The cx is a drop in.
Old 05-29-2018, 08:31 PM
Blue Tick's Avatar
Blue Tick
Perfect....I will keep those both in mind for the pak pods.
For those that have used the CV amps, is the B54 worth the $$$ to keep this as a solid build and a smaller budget? Or is the diamond that much better of an amp.
Old 05-29-2018, 08:39 PM
Blue Tick's Avatar
Blue Tick
Originally Posted by InthewindMN
This pic shows the molex connectors and LL you are looking for.
What is the procedure for running the LL to the CV amp since there are no rca inputs on them or am I not picturing it correctly?
Old 05-29-2018, 08:46 PM
InthewindMN's Avatar
InthewindMN
InthewindMN is offline
the b54 has rca inputs on the pigtail connector.
Old 05-29-2018, 10:44 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,239 Likes on 1,002 Posts
The B54 is not a good amp to build off of because it lacks power for 4ohm setups.
Old 05-29-2018, 10:57 PM
Blue Tick's Avatar
Blue Tick
Thank you.....other amp I was looking at was the micor4v2. Other suggestions that work well in the batwing fairing?
Old 05-31-2018, 10:21 AM
Juice's Avatar
Juice
Juice is offline
The 4v2 is basically the same amp as the B54, just better internal components. same chassis and same owners manual.
I also have a CT sound amp that has the same chassis and specs just less expensive.
Old 06-19-2018, 06:22 AM
Badbagger09's Avatar
Badbagger09
Badbagger09 is offline
Question: If I am only setting up for front speakers do I need to only one set of RCA cables?
Quick Reply: Install Help...Pics/Diagrams
