Fairing Only Setup
Fairing Only Setup
I have good experience with car audio but this will be my first bike system. I finally traded my first love (Fatboy) in for an 18 SG. After researching this forum and online I believe I have the setup I want. Thought I'd run it by you guys to see what you think and hopefully get some insight on a few questions.
Sound quality has always been more of an interest than giant subs in my car so I thought this setup would work best for me.
I don't think I'll have a problem hearing it with my riding style. Long country roads about 70mph.
Setup
Sound Processor - DSR1 Rockford Fosgate with signal wiring harness front and rear(americanhardbag.com)
Mid Speaker - DD AW 6.5 (ddaudio.com for those that want to look at them - purchase will be from one of their dealers)
Tweeter - DD VO-B3 (ddaudio.com for those that want to look at them - purchase will be from one of their dealers)
Amp - JL M600/6 Bridged two channels for the mids 200RMS and the other two for the tweeters 75 RMS(crutchfield.com)
Amp Power Cables?
Amp Mounting Bracket?
Speaker Bracket (biketronics.com)
Tweeter Pods - Fiberglass work to make the VO-B3s fit (jarzproducts.com)
Questions
The amp accepts 4AWG power cables. Can I run this size without much trouble to the battery?
What amp mounting bracket are others using for the JL?
I plan on using the speaker bracket because I assume the AW6.5 could use the extra air volume. Unless others recommend keeping the stock pods?
I plan to have the radio flashed for 4 speakers no amps. That's why I'll get the front and rear wiring harness for the DSR1. I may add lower fairings or bag speakers later. Plus, I could easily use the fade to adjust tweeter to mid balance on the fly. Initial setup will balance them but I thought having the option while riding wouldn't be bad either. Is this a good idea?
To tune the system flat and then make EQ changes for my personal preferences I thought about using the android app Spectroid. The app has good reviews and either my phone or a mic can be connected for more accurate reading. Has anyone used a similar app? If yes, did you use a mic?
Setup
Amp Power Cables?
Questions
AAWAV
Audio Systems
11
02-06-2015 01:00 PM
