Newbie audio question. Be gentle. 😀
First off thanks for the add. Love all the info available on here.
So here’s what I got. 2015 Street Glide Special with boom audio stage 2 in fairing and lids. Amp in fairing and also in saddlebag. I’m wanting to upgrade the the front speakers and amp to something better. Looking at BT 2180.14 amp and the Hertz MPX 165.3 for the front. Now, lol, the quest is for the rear. I would like to continue to use the Boom Audio amp in the saddlebag due to the fact of the giant hole in the bag for the wire harness. Is there a 5x7 or 6x9 (with adapter for HD factory lids) that will sound better than what I have with that amp or am I wasting my time?
Looking for decent mid bass and clarity without having to add subs. Budget is unknown. Just picking some brains and looking for some recommendations. As far as the hole in the bag for the harness for the rear amp what would you suggest on that also. Wanting to keep the factory head unit also.
Supertrkr (05-24-2018)
Let me just say, I’ve been exactly where you are now, and ended up ripping all that is Boom, out, and replacing everything but the H/U. I am so glad I did. I converted the lids to 6x9’s via., Vtwin audio adapters. It was a **** ton of work, but saved me an additional $500-$700. If you’re not concerned about money, there are several other options; Bad Dad, Hogtunes, Rockford Fosgate, twisted 8’s etc., etc. Then, you have the dreaded pods. I kept mine, and added polyfill. Others say Fk it! And tear them out and use the Biketronics speaker mounts. It’s a constant battle, but worth it. Looking back, I wish I could’ve just found a sound shop, and have them do it. It’s a LOT of work!
As Baff and others eluded to, ditch the boom amp and go with a good 4 channel amp up front. The boom set up is 2 ohm and biamp setup so there are no aftermarket speakers that are compatible with that amp. That bt2180 is a good amp but has no adjustments on it. A tm400x4ad is perfect for a 4 channel setup and if you can swing it, hertz mpx 690.3 are the best 6x9 out there right now. The new wdx 6x9 are also good but not as warm as the milles. Baff is running polks mm series in the back. I personally have not heard these (yet) but have heard the others. At present I am running the tm400 and the milles in the rear and really like that setup.
