Is 12 Gauge good enough
So it would need to be 8 all the way to the battery. I was going to use a junction block and split to both amps. But the 4180 only requires about 12 and that wire is all ready ran.
I might run 8 from the battery to a block then 8 to the JL and 10 to the BT4180. I don't think the BT will accept any thing lager than 10. Hell, I'm struggling to connect 18 G speaker wire to the BT speaker outs . I hate their speaker connections.
You're barking up the wrong tree right there. BT amps are extremely clean sounding and very accurate. 180 x 4 half the size of a Hertz HDP4.
