Just bought the RF HD14-TKIT and TMS65 '14 FLHTK
As Gypsye alluded to, the devil is in the details regarding the specific "flash." Lots of shops are doing the so called "flash" thing but 90% of them don't know their **** from a hole in the ground regarding the Boom HU. They all swear their shix sounds awesome of course!!
If you know the exact "flash" they are using, I'm certain u will get some better feedback. Probably some more sled audio shop proprietary info though!!!! Lol!!
The BT355 is a very damn solid play here.
T.
T.
That's the point. You wont know until your stuff goes up in smoke. If it has too much voltage from bass that the HU puts out it will eventually burn the amp up. Again if your indy has done a bunch of aftermarket installs on boom systems, he may be able to flash you hu right. I for one would rather spend the $85 on a line leveler and be done with it.
Originally Posted by AssaultVehicle95
Ok thanks for the info. So hypothetically... if I already wasted money on a flash, how would I know after the install if the flash worked properly or not?
T.
So.... one last question before i open the boxes tomorrow. I decided on going with the RF speakers on the front (TMS65), but now im considering going with the polk mm1 series in the tour pak instead of the TMS65. Anyone have any experience with both of these speakers or have any input on which one i should go with? I paid 225 for the RF rear pod speakers. I can get the polk for 150. Thanks again guys.
