I have the Sony MEX70bt HU and arc 600 amp, I am attempting to listen to one speaker at a time. I have the the fairing speakers on one channel and the lowers on another. when I set the fader to the rear I dont hear anything. What am I doing wrong?
Also is the amp input set on 2 channel or 4 channel?
just looked at the PDF for the amp, I will take the fairing cover off and check the input. I have it as the Arc Moto PDF has it and and that is set at 2channel
If all speakers work when in neutral mode on the fade try just fading from front to rear. If all go out when fading to rear you have the amp in 2 channel input.
