Need some pro advice again on gains/clipping
so have the JlMX500/4 with ddaw's and AT28 tweets they sound great but still getting some clipping at very high volume I had set gains at 31.6 volts with all flat and motor on. The target voltage in the Jl manual says target voltage for bridged to 4 Ohm should be 31.6 After reading the sticky thread from Sly's chart, i should be at 44.7 v I did a small test run and didnt clip until almost full volume at 80. Question is which is right and can i hurt something with too much voltage
