What would be my best bang for buck audio set up for a $500 to $700 dollar budget
What would be my best bang for buck audio set up for a $500 to $700 dollar budget on a 2012 Road Glide I will be running just fairing speakers and I would like to get a bluetooth set up i was thinking about starting off with the aquatronics head unit if it is any good. I just need to know the best speaker and amp set up that all work together.
Thank You
Thank You
Thank You
Thank You
If you are staying just with the fairing speaks I would suggest the cerwin Vega b52 amp and to top it all off and let you enjoy the tunes thru the DB WDX6
To start out I would suggest an aftermarket headunit other than the aquatics which has limited functions and go with a Sony or similar headunit that has the ability to invert the display (white background with black numbers/lettering) since you are on a roadglide. Which will run you around $250 give or take a few bucks for the kit that includes the handlebar control module to retain you bar controls.
Perfect set up for a budget build.
I like that setup just a few more questions
Looks good is there a mounting bracket kit that I need to get to mount that b52 amp. Also do those speakers mount right up to the old. Where do I buy the kit to make my handlebars still work with a sony head unit. Also my bike is an ultra and I am going to be taking the touring pack off I was told that I need to get special caps to block off those speakers so I don't blow my head unit.
Road Glide Matt
04-24-2018 10:42 AM
