Buying amp. Biketronics or Rockford
Originally Posted by Big trucker
is it false then that I致e read that the tm400x4ad puts out significantly more wattage than advertised? Even calling in and talking to them they said it was closer to 600 total watts not 400
Originally Posted by SOFTPETER
I agree. Also its about fine tuning your sound not just blasting it. YMMV.
dont get so butt hurt dude.
There are some here that offer advice that are nothing more than a parrot repeating what they've read somewhere else and have no real world experience with the product they're referencing as often don't even repeat it correctly. Others just plain out give bad advice.
Not butt hurt at all. Bad advice is bad advice no matter how you present it.
well I do appreciate you taking time to give me input. I don稚 know much about audio and it痴 very overwhelming
Sorry, but I'm hi-jacking the OP's post, but I have the 4180 with LL's. The price on this DSR1 is tempting, but am I going to achieve any noticeable improvement in sound versus what I have with the line levelers?
I understand that the BT 4180 has no user-adjustable gain control (which is partly why I bought it in the first place - KISS method) and I also believe that there are preset frequency filters built into the amp, correct? So is it a totally moot point to ditch the LL's & get a DSP? Is there a tangible amount of increase in control between the two that will help "richen" the sound I'm getting?
I should add that I'm running the BT Titan 2 speaks, which I am very (and painfully) aware are a bit bright for front stage only, so the plan is to upgrade to the DD AW 6.5 component setup eventually.
I know for a fact it's overwhelming. We've all been there at one time or another. To help you understand a bit more about the RF400x4 here's some details, and they'll mean more to you the deeper you get into learning about setups. The RF's power is the same whether your running 2ohm or 4ohm speakers. This leaves you no room to grow your system. Let's say your running fairing speakers and tourpack speakers and both sets are 4ohm and you want to add lowers....with most amps you could parallel 2 sets of those 4ohm speakers and bring your load down to 2ohm and benefit from the amps higher output at 2ohm. This amp doesn't offer that luxury. Again, same power regardless what you're running. Personally from my experience the amp just doesn't deliver a good sound.
If your going to add lowers or lid speakers, then you should probably go with 4 ohm speakers from the get go if you plan on running 6 speakers off one amp eventually. You will not be able to do that with the 2 ohm Kappas. You may want to put something like the DB Motos in the fairing, then later you can add another set in the lowers at a later date (in parallel of 2 channels when you add lowers) or go with the Polk MM 652's in the fairing and tour pack (in parallel of 2 channels when you add lid speakers) and add lid speakers later.
I was told the coupon for pacific stereo didnt work anymore when i bought my focal not too long back, cant remember what the code was but i entered it at checkout and got 25% off so i paid $600 for it. Saying that to say find the coupon code and give it a try, had i listened to what i was told on this forum i would missed out on a great amp, or paid more for it.
