Rockford Fosgate pbr300x2 installation help.
Hi SOFTPETER! Can you share your experience with this new AXXESS LLC? Are you running one? How does it performs in comparison to the BT355? Is it easy to install? Thanks brother.
T
T did you end up installing one? What's so bad about it? I spoke with Jeff at their tech support helpline and was told they work exactly as the BT355. He guaranteed me it will work for my application.
Thanks for commenting Mike, that was one of my concerns. When I brought it up to their tech support guy, he explained the 80-watt max output applies to the head unit output, not the amp. Being the Boom Infotainment delivers 25 watt per channel, the Axxess LLC should work fine.
Big trucker
04-04-2019 06:42 PM
