New Speaker and amp install on 15 SG
Originally Posted by Dsm Limited
you also need to wire the "trigger" wire. The one that is controlled by switched power, like the cig lighter, one that comes on with the ignition. There should be a 2 wire plug near the top of the fairing on the brake side. Should be by the speaker pod and have a blue/ purple wire. You can use that wire for the trigger or tap into the blue/ purple on your accessory outlet.
http://www.vtwinaudio.com/store/prod...ire-connector/
https://mstore.harley-davidson.com/s...E&gclsrc=aw.ds
This remote turn on removes power to the amp when the acc switch is off and closes the circuit to turn on the amp with the acc switch on. Without it the amp would be hot all the time sucking the life out of your battery.
T
Alright if I tap into the accessory wire then where does that wire go to on the amp? There’s a place for speaker wire. Then the ground wire and the 12v wire which is going to the battery and theres the input and output. Then i guess theres supposed to be rca cables but how do those go into the amp if they do or how to they go into the stock stereo headunit. Theres litterally just a giant wire loom coming out of it
Also where did you run your ground wire to?
You wire it to the Remote on the amp. For the RCA's you should have a pig tail with the amp for the RCA's.
Attachment 589448
Attachment 589448
okay so tiny skin wire from maybe that cig lighter looking thing to the remote port in the amp. i have the pigtail that plugs into the amp with the two rca female acceptor ports. i have ground wire straight to the battery. i also have that other wire that plugs into the amp and then goes to the speakers
Or get one of these to tap into the remote turn on or trigger wire.
T
T
