Power Supply?
Power Supply?
I picked up a power supply from the local pawn shop.
It is a-
10 SR power supply
Precision regulated
output: 13.2 vdc 10 amps
input 115 vac 60 Hz.
Short Circuit Recovery Automatic.
Made in the USA
Can I hook this to my battery leads and use it for my constant power instead of starting my bike when I want to try and tune my setup. Or will this mess with my electrical system.
I'm thinking it will work fine but thought I should check first.
Thanks
Brad
It is a-
10 SR power supply
Precision regulated
Made in the USA
Thanks
Brad
I agree plus I think that it may cause a hum in the audio like most power converters. I suggest getting a trickle charger or battery tender and just leave it plugged in while you adjust you set up. Most of those have a green/red light to indicate charging/charged mode.
ABSOLUTE GARBAGE !!! HOW is this JUNK EVEN CONSIDERED a HARLEY, this is an APPLIANCE !!! A PLUG IN SEWING MACHINE, DISGRACEFUL to REAL HARLEY RIDERS. IF this WAS the ONLY HARLEY YOU COULD BUY NOW. I WOULD NEVER BUY a HARLEY, I WOULD WALK. ABSOLUTE CRYING SHAME Harley is CAVING INTO the MASS ENVIRO( MENTAL CASES ) to TRY and GAIN NEW RIDERSHIP ! NEVER GONNA HAPPEN WITH this SPACE AGE APPLIANCE CRAP. This is NOT SHOWING LEADERSHIP, this is SHOWING HOW SHEEP the COMPANY HAS BECOME
