Rockville woofer
not a good fit at all. I could not top mount them in my mutazu lids so I had to add spacer and mount from the bottom. I was suprise that I had enough clearance for lids function properly. So far I only have two nuts and bolts holding them in. The other two dont match up. I only have right woofer in but so far the pioneer 6900`s has more bass output. I will try bridging one side of pn4.1000d to see if they need more power. I sent the wrong model amp to a friend. He ordered the pn1.1000 mono amp. That amp has 600 rms in 2 ohms. I ma get from him and add to my sled but so far Rockvilles arent impressive
Originally Posted by Delgado130
Rockville RVL69W Competition 6x9 300W Peak / 150W RMS woofer
These might be a better side by side competitor.
https://www.rockvilleaudio.com/rv694a/
If ur looking for just thump I'm sure adding some juice will bring these to life but that dynamic freq range & top end will be sorely missed rolling down the road. With the right power those things should pound.
T
Just ordered those since they were only $40! I will bridge amp and see if it makes a difference. As I stated earlier in post Im looking for more low end. The mmats and b3 horns are awesome! I'm still trying to find the perfect 6x9. So far the ts6900's are a top contender but I still wanna try the jbl got 939 and especially the mmats 6x9's. Hoping someone on this forum had a set so they could tell me are they worth getting
Just wired up Rockville 6x9's to Soundstream pn1.1000d. This setup at 2ohms hits! I have amp crossed over at 150hz. I now have no rear mids and highs so Im thinking bout ordering dual 6x9 lids. I prefer subs down low in bags but local installer wanna charge $300+ . Vivid black dual 6x9 lids are only $130 but I didnt want all that weight on lids.
BaggerAudioLab
Audio Systems
241
06-22-2021 04:17 PM
cfave
Audio Systems
09-10-2018 01:38 PM
