Anybody ever mixed pioneer 6900s with dd vo 6x9s?
Sorry for the delay in updating my post...After I made the order with babyboy he notified me that the ddaws and at28s were on backorder and I haven't received any of my packages yet...ii will update you guys once all the pieces are in! We also changed the plan from the at28s to the ddt20 tweets due to the at28s not being available till June! I purchased a 800x4 2ohm sd amp and rf dsp from gannicus recently and will be powering the quad 6x9s (4ohms) in parallel with the 800w sd amp instead of the 400w sd and using the arc audio 600.4 for the aw's and tweets...and I will have to make a choice between using the rf dsp or the arc audio dsp...
T
Wish I could...I believe the AWs came in on the 30th so they should be on the way to me...im gonna check with baby boy...cause its been about a month of waiting
So T, what is your go to woofer replacement for the AW 6.5? Do you have a preferred woofer/tweeter combo replacement for a fairing only setup or possibly a fairing/6x9 lid setup?
