Gain settings and speaker buzzing
Old 02-27-2018, 11:43 AM
travelingypsye's Avatar
travelingypsye
travelingypsye is offline
Originally Posted by Fblo1690
ok so i misread the chart. im not a stereo guy at all. lol. So i need to turn my volume to 3/4 and adjust gain till 22.4 looks like?
so another question. whats the point of all that room left on the gain adjustment? would i benefit from upgrading speakers? Or is the issue the Factory head unit?
Every set of speakers and amp is different. Even 2 sets of the same speakers will require a different gain setting. Same goes with the amp. None are the same. The manufactures of amps make them to deliver power to a vast variety of set up including running 4 speakers off the 2 channel amp. In most cases gain will not go past 2/3 to 3/4 on the ****. Turn the gain down, don't use a volt meter, check your speaker wires and if all is set right, they will sound good even if only half gain on the ****.
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,239 Likes on 1,002 Posts
Ground is all the way to the battery. I tried the old school way. I dont have an ear for that. ima technical guy. id rather use the meter. no offense.
Your still gonna need to rely on your ears to set it. Using the meter is just a starting point. It's not a definite setting.
Old 02-27-2018, 11:46 AM
travelingypsye
No worries my brother, I'm not an expert by any means, We all had to start somewhere. Use your volt meter and get it close then tune by ear for optimum sound to you.
Old 02-27-2018, 11:50 AM
travelingypsye
Sorry Bates for being redundant. I was typing at the same time as you....I'll shut up now.
Old 02-27-2018, 11:53 AM
haze324's Avatar
haze324
haze324 is offline
Originally Posted by SBates08
No disrespect to anyone here, especially the OP, but this is why I NEVER suggest setting gains with a DMM to an audio newb!!!!!
Set your gains the old school way. Turn gains all the way down, set treble and base to neutral, turn radio up to 3/4 volume and adjust gains until you hear distortion and back off a bit.
Also, run your ground to the battery. Not on the neck or triple tree.
+1
The thing with audio and making adjustments is that if you use a solely technical solution and lets say you do it 100% correctly and the music coming out of the radio sounds bad how do you make adjustments. In the end it will be by what you are listening to and not a math equation and number on a screen or red light on a device.
cfave (02-27-2018)
Old 02-27-2018, 11:54 AM
SBates08's Avatar
SBates08
SBates08 is offline
No worries. We're all here to help.
Old 02-27-2018, 02:14 PM
Fblo1690's Avatar
Fblo1690
Fblo1690 is offline
Default Speakers
yes guys (maybe gals) I appreciate the help. I’m looking for speakers now. My right one has a slight rattle. Their older xfinti
Old 02-27-2018, 02:15 PM
Fblo1690's Avatar
Fblo1690
Fblo1690 is offline
What ratings should I looke for on speakers to pair well w my amp
Old 02-27-2018, 02:50 PM
Fblo1690's Avatar
Fblo1690
Fblo1690 is offline
Can I get 4ohm speakers and run them in bridge setup?
Old 02-27-2018, 02:56 PM
SBates08's Avatar
SBates08
SBates08 is offline
You need a 4 channel amp to bridge to 2 speakers.
The B52 will do good with either 2 or 4ohm speakers. I'd take a look at the DB Motos.
Quick Reply: Gain settings and speaker buzzing
