Affordable Fairing Amp on a budget
#31
#32
That B52 is an interesting little amp. I noticed a weird socket on it labeled BTR port. Their website mentions connecting a Bluetooth receiver though this port but I don't understand the concept. I thought Bluetooth was handled inside the head unit itself. Are there special Bluetooth receivers that plug directly into amps now?
#33
#34
Well almost. If you turn down the gain on the amp all the way, it wont matter what the hu volume is, you wont hear it. Turn the volume 3/4 up. Start adding gain until distortion. Then back it off a tad. Make sure the hp filter is on and around 80 or so. That should get you close by ear and make those kappas sing. If you have a digital volt meter, there is a sticky thread on how to set up you amp based on watts and ohms of your speakers. Very helpful.
#36
#37
I believe the instructions sat they are for when installing the with a stock HK head unit. I basically disregarded the instructions for them as I was installing a sony head unit.
#38
Yea. On that amp it is marked x over. Switch it to hp. Just to the right of it is the freq. ****. Turn it till you think it is about 80-90. Should be good to start taking your gain (sens) up till you hear distortion then back it off a bit.
#39
