MMATS and AD CX62 Amp ?
I am officially hooked. I have a 16 RGS and it started with the basic kappa's only, then CV B52 and kappa's, then B52 and AD CX62's (which sound awesome by the way). Now, I have purchased mmats pa601.4's to go with my AD CX62's and am looking at replacing my amp (all of this since October). I like everything about the Soundigital 800.4. Price, output, size. Everything except no crossover adjustments. I have read quit a bit about others with mmats and seems most cross them around 100-110Hz.
My question is, would this work at the amps fixed 80Hz filtering with the mmats as long as I kept the power down going to them? I would really like to have everything on one amp and no DSP if possible. My other option right now would be the SS PN4.1000D as it should push enough power for all 4 speakers but may be a challenge to fit it in the RG fairing. Thank you guys for any input and guidance.
Thanks Haze. I kinda figured I would really need one but had a little hope I could get by without one. Do you have a different amp you prefer with this setup or should I look at running multiple amps? I appreciate the input. You guys are a wealth of knowledge and have helped me tremendously along this journey.
