Hogtunes
Hogtunes
Friend is looking at this Hogtunes kit http://www.hogtunes.com/products/sel...4sg/combo1.php
for his 2014 SGS. I know kits are not preferred and I’ve tried to talk him out of it. Dollar wise what would be close that I could talk him into that would be better? Thanks
So here's the other thing you have to do for both "plug and play" and other systems:
-take fairing off
-remove stock speakers
-remove gas tank
-run power and ground to battery
-wire remote turn on
-install biketronics LL
-install amp bracket
-tune
-put everything back together
So if you want to spend less cash, spend a little more time and have a much better sounding system? Then don't go with the "plug and play" kits.
-take fairing off
-remove gas tank
-tune
- Set of 4 Infinity Kappa 62.11 6.5" Speakers
- One Cerwin-Vega B52 Stealth Bomber Class D Amp
- One BT355 HD Radio Line Leveler and Pre-Amp adapter for 2014 HD and up
- Street/Classic/Road In -Fairing Rear Speaker Connector for 6.5 Navigation Touch Screen model.
What else do I need wiring and hardware wise to do this install?
Thanks for the help!!
