Biketronics New 250w x4 at 4 ohms Amp
#202
Average Joe will likely pick a decent coax speaker, while the JL does put out a lot of under rated power at 75watts x4 or x6 (@ 4 ohms) depending on the amp.
The coax speakers are not as efficient as say a pro audio speaker and alot of time will require more watts on a bike at speed to be able to hear it.
Hope this helps.
Hope this helps.
123ozzie (06-15-2018)
#203
Hope this helps.
Hope this helps.
An example could be something like the AW6 speaker that takes 150 watts plus to get it moving into its wheel house thus u would need to bridge this amp locking up channels 1-4, and leaving u 75 watts on 5 and 6 for 2 other speakers.
Point being, if you are interested in rolling in on this amp, as it is a damn fine SQ amp, a bit more care should be taken to match the entire setup versus purchasing the amp them hoping for the best as u build a coax or component setup. This amp with 4 PAs and Horns is probably one of the most popular being used as that type of efficiency in the speaker and amp pair very well together.
T
#204
#206
#207
#208
Another up date on the 4250! I took it out on one of my usual backroads ride for about 5 hrs. Previous to that I only heard it after a couple hrs. of tuning then beating it up the GRR to Black River Falls for the M&G (avg mph was 75-80)! So comparing the new 4250 to the 4180 on my usual ride cruising at 50-60 mph I could hear all my music better! The VO 6.5's in the lower were louder and hit harder and it woke up the HAT SE's and I could hear them better. they hit harder and I could hear a lot more detail in my music! I really like the way this amp sounds, still need a little tuning and I am going to try some different speakers in my fairing that will keep up with the other 3 sets! MM
