2012 Police Electraglide. No thumb controls
Where I stand at the moment is:
I have color wiring diagrams that seem to match up very well to harnesses in the bike.
I sent Kuryakyn housings back and have a set of HD on the way.
I have replacement switches for all of the needed switches
I have the volume switch (LH) and I have the mode switch (RH)
When I receive the new housings I will install the switches, take off the bars and sleeve the wiring inside and the re install the bars.
I have a new console switch for the passing lamps that will be eliminated for the mode switch.
At that point, I will start wiring.
I have not purchased an HD or HD upgraded radio yet nor the 23 and 35 position radio female connectors. 1 thing at a time.
That is where I am at.
Don
i would certainly recommend using an aftermarket head unit such as sony, kenwood, alpine or pioneer, for the simple fact they will give amazing sound quality over a stock replacement, with that being said, you do not need the 35 pin housing, only the 23 pin, and there is also no need to wire in the 4 front speaker wire as you definately want to install an amplifier, then connect your speakers to output side of your amp
Thank you for the feedback. I have looked the the Sony with the Bluetooth and hidden door for your phone. I purchased a RF amplifier for the cheapo radio I have now. I will definitely put it back in. The speakers I purchased last year are from J&M. Do I need to be concerned about the ohm rating?
Sandor
04-30-2018 11:49 PM
frankiejr
07-11-2016 11:39 PM
