Sound insulate the fairing
Has anyone who has used any kind of soundproofing like dynamat or similar material to insulate the inside of the fairing think its worth the cost? What about the sprayon types like DEi boom mat sound deadening spray?
I installed new amp and speakers,inside the pods, and I going to try the polyfill wrapped around the pod. Cant hurt its cheap.
T.
I had to do the pod mod so the speakers I bought would work . I cant justify spending 200 for a set of brackets to do away with the pods. I’m thinking of buying some adhesive spray and polyfill and wrapping the pods in it.
If your speakers never change I agree it's hard to spend the money on brackets, but stay in this forum long enough and things will change and you'll wish you had the brackets from the start. I know I did.
Im not doubting anyone here,but why is it better to use the brackets instead of the pods?
I know squat about audio stuff and how it works. Im sure ill be looking at getting the brackets but not now.
Most of the speakers I used within the pods were getting snuffed out so I drilled a few (6) holes in each. Sound improved. Made the holes a little bigger, sound improved. Removed the pods and installed Dynamat and sound continued to get better.
Keep in mind that there are speakers that do like being in those pods so hopefully a few guys can chime.
Part 2 of this is the pain in the **** involved with taking the pods off every time u want to tinker with ur audio, be it a possible loose connection or trying new shix out. Getting kicked in the ***** is very close to the feeling I get when I record and replaced the pods. Plus I needed stitches on my knuckles after each R&R cycle.
Plus removing the pods opens up usable space for audio accessories like external crossovers and micro amps.
Better sound depending on the speaker, much better access, and more room for advanced shix are the primary reasons I can think of.
Not the end of the world if u don't want to pay the cash for the prackets, however be cognizant of the speakers desire to breathe just a bit.
T.
