Amp wiring question
Amp wiring question
Thanks again to all who responded to my inquiry regarding J&M speakers vs OEM. On your advice i purchased an amplifier along with the J&M speakers. I found the J&Ms for a good price of $79.95/pr from www.directcycleparts.com (most places wanted nearly $120/pr)..The amp is a DUAL DA704L, which i mounted on top of stock H-K head unit in fairing. Does anybody have any tips or advice as to what is the best route to run the wiring for the amp? I removed the fuel tank and planned on running the 12v power wire on left side of frame and speaker wires on right side. Any thoughts ?
Thank You
Thank You
rpmerc86 (12-04-2017)
What is reason for running ground directly to battery? I’ve done automobile amp installations years ago and would always connect power wire directly to battery but make ground no more than like 3 feet.... just curious. Thanks
Originally Posted by rpmerc86
What is reason for running ground directly to battery? IÂ’ve done automobile amp installations years ago and would always connect power wire directly to battery but make ground no more than like 3 feet.... just curious. Thanks
So would that be the reason that I hear the engine humming at high rpms?
I just installed a 200 watts amp using high level (speakers signal not RCA) connections. I installed the amp in the trunk, but grounded the -neg from the high level to the metal plate in the tour pak. I also grounded the amp to the same place. The reason I grounded those two to the metal plate inside the tour pak was because the antenna and CB are also grounded there (I thought it was a good ground). But I hear the engine rpms and distortions the sound.
Thanks in advance for your input.
05 Ultra Classic
+ pos to amp is fused with a 25 amp, and feeding off the battery positive.
Originally Posted by papichuloy2k
Greetings,
I just installed a 200 watts amp using high level (speakers signal not RCA) connections. I installed the amp in the trunk, but grounded the -neg from the high level to the metal plate in the tour pak. I also grounded the amp to the same place. I grounded those two in that metal plate inside the tour pak was because the antenna and CB are also grounded there.
05 Ultra Classic
05 Ultra Classic
papichuloy2k (12-11-2017)
Ride safe,
K
