Pinched Wire? Tracking issue.....
System In My 2009 Ultra Classic
Radio: Aquatic AV AQ-MP-5UBT-HS
Amplifier: ARC Audio MOTO 600.4
Fairing Speakers: ARC Audio 6.5
Tourpak Speakers: Alpine SPR 50
Issues I am having:
Rear speakers cut all the way out after awhile.
Front Speakers - RF cuts out occasionally after awhile and then comes back on.
The AMP indicator light stays a steady green (I have it mounted where I can see it all the time, even while riding) No issues with the amp.
I pull the outer fairing and the rear speakers start working fine.This is the second time I have pulled the outer fairing off and it seemed to correct all issues. I found a wire that was rubbed through and corrected it. Worked fine for awhile and now the same issues again.
I assume I have a pinched or bare wire somewhere.
Anyone have any other suggestions? I have the fairing off now and messing around looking for anything unusual.
Any help or ideas would be appreciated.
Issues I am having:
I went and reorganized the wires behind the fairing, trying to avoid any "crinks" anywhere. I also taped the RCA's connections together. I also found some wires that were starting to rub through and fixed those.
I went for a 40 mile ride and everything seems to be working. (For now...LOL)
Thanks for your suggestions, I appreciate it!
XTsHOG
Audio Systems
06-08-2017 08:43 AM
