mounting tweeters
Old 10-10-2017, 06:42 PM
Scooby1426's Avatar
Scooby1426
Scooby1426 is offline
Default mounting tweeters
Just got my speakers today. Thanks to Alex from baggeraudiolab! My questions are:
1) Do the speakers hook right up to the bk pod eliminators?
2) with the hog-tunes speaker grills how does the bracket hold these in?
Old 10-10-2017, 07:07 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
What speakers?
What tweets?
T.
Old 10-10-2017, 09:04 PM
Scooby1426's Avatar
Scooby1426
Dd aw6 & at28 speakers.
Old 10-10-2017, 09:22 PM
BaggerAudioLab's Avatar
BaggerAudioLab
BaggerAudioLab is offline
scoob the BT brackets are pre drilled for 6.5 they’LL Line right up. For the tweeters use a 1 3/4 hole saw and some black silicone to hold them in place.
Old 10-11-2017, 07:03 AM
BlackPearl#1's Avatar
BlackPearl#1
BlackPearl#1 is offline
BLACK!!!! for sure. No matter what you do, you'll see a little bit of it and the clear is very visible. Lesson I learned the hard way. Good call Alex.
Kris
EDIT: This might also help a little. https://www.hdforums.com/forum/audio...ur-grills.html
Old 10-11-2017, 06:01 PM
Scooby1426's Avatar
Scooby1426
Thank you for all of your help. Suppose to rain here on Saturday so i am looking to start on this then. Only thing i need to get is speaker grill cloth & that should do it.
Old 10-11-2017, 06:50 PM
BlackPearl#1
Where are you in WI? I got tons of it
Kris
Old 10-11-2017, 07:09 PM
Tailwind's Avatar
Tailwind
Tailwind is offline
Just don't drill the initial grill hole too big. U want that damn tweet to slide in nice and snug using the silicone as an additional securing measure. Us dremmel to fine tune the size of the grill hole. If u take the time to get some grill cloth it really cleans up the finished look.
T.
Old 10-11-2017, 07:48 PM
HD_Doobie's Avatar
HD_Doobie
HD_Doobie is offline
Rather than use silicone, I flattened out the clip for the back of the tweet. This made the clip longer and the screw holds them nice and snug. One other small tip is I took a black sharpie to the wires on the tweeter. I didn't want to see the red wire thru the grills, and this seemed to do the trick. I used a 1 7/8" hole saw and it worked perfect. Put a layer of masking tape on the front so you can draw some lines to find the exact center. Clamp it down well, run the saw in reverse and go sloooowww.
Old 10-13-2017, 06:35 AM
Scooby1426's Avatar
Scooby1426
Thanks again for your tips. Looks like this weekend forecast rain in Milwaukee so the time has come to do my audio upgrade.
Quick Reply: mounting tweeters
