New FOCAL Fairing amp 4x175w!
Old 02-05-2018 | 03:00 PM
travelingypsye's Avatar
travelingypsye
Originally Posted by DAVENRINO
How is everyone mounting the Focal Sport in a Rushmore Batwing? Double sided tape and zip-ties to the stock bracket? Or is there a way to bolt it in?
Thanks,
Dave
I used the "feet" that come with the amp. Then laid the amp in the amp tray to mark the feet. Drilled 9/64 holes in the amp tray and used the sheet metal screws that came with the amp.
Job done.
  #382
Old 02-05-2018 | 09:11 PM
DAVENRINO's Avatar
DAVENRINO
Job done.
Thanks a lot. Did you use an inline fuse in addition to the internal fuses? If so, would that be a 50A?
Dave
  #383
Old 02-05-2018 | 09:56 PM
SBates08's Avatar
SBates08
I noticed that twspalm stated he was running this amp in a Rushmore without a LL or a DSP. How is this possible? Have to do with the Flash he's using maybe?
  #384
Old 02-05-2018 | 10:54 PM
travelingypsye
Dave
No I just have it direct to the amp. I thought about an external fuse but didn't take it apart to see how the 2- 25amp fuses are configured. If parallel ok, if in conjunction they will blow before the 50amp you put in line will blow. Just saying.
  #385
Old 02-05-2018 | 11:26 PM
DAVENRINO's Avatar
DAVENRINO
I talked to Andy at Riverside Pacific Stereo and he said they install them without LL but does require a flash. He said they just run the Speaker lines from the stock HU to the high level input. I thought the gurus here said that sending all that processed audio to the amp wasn't the ideal setup.
  #386
Old 02-05-2018 | 11:28 PM
DAVENRINO's Avatar
DAVENRINO
Thanks, you would think they would supply one if it was necessary since they do supply the power lines.
  #387
Old 02-06-2018 | 12:11 AM
travelingypsye
It may work for a bench test but I would cringe to ride all day beating the amp with all the high/low input straight from the head unit. I for one would rather not worry about my amp with a line leveler. Besides I have read the nightmares of HD techs trying to flash the hu and it sounding good going down the road.
  #388
Old 02-06-2018 | 12:25 AM
DAVENRINO's Avatar
DAVENRINO
Yep, I ordered a couple today along with the BT brackets you are trying to avoid buying.
  #389
Old 02-06-2018 | 07:31 AM
Roadie13's Avatar
Roadie13
When I talked to Focal they absolutely said to install an in-line fuse. They didn't give a specific value but said it needed to be greater than 50A. I went with 60 because I had an extra from my other setup. Definitely weird that they supply the wiring without a fuse or eyelets for the battery. Easy fix, but should be included for a top tier amp.
  #390
Old 02-06-2018 | 07:44 AM
travelingypsye
Good to know. Thanks.
Quick Reply: New FOCAL Fairing amp 4x175w!
