New FOCAL Fairing amp 4x175w!
Old 01-02-2018 | 05:39 PM
flcusat's Avatar
flcusat
Originally Posted by Tailwind
Now if u can get me a quality 200x4@4 amp with the same footprint, I'm all over it.
T.
You are asking too much.
  #232
Old 01-02-2018 | 05:47 PM
Outkast6991's Avatar
Outkast6991
T.
No love for the soundigital 800.4? Not sure on the size comparison but specs say 200x4. It is at 2ohm though
  #233
Old 01-02-2018 | 05:50 PM
USAproud's Avatar
USAproud
That is 200x4 @2ohm
  #234
Old 01-03-2018 | 06:49 AM
Gannicus's Avatar
Gannicus
For my build there really is not much I need to say beyond the "more power" aspect of the equation. The Focal is powering 4 JL880s and they luv that thing. Killer SQ and very efficient as well. In a nutshell, it fit my build. Now if u can get me a quality 200x4@4 amp with the same footprint, I'm all over it.
T.
I'll have what he's having. . . Only the 6 channel version. lol!!
  #235
Old 01-03-2018 | 07:49 AM
flcusat's Avatar
flcusat
Is there a 6 channel version coming up?
Gann, what amps are you running now?
  #236
Old 01-03-2018 | 10:06 AM
Gannicus's Avatar
Gannicus
Just kidding bro! I was basically saying when they come up with a 6 channel amp rated at 200 watts per channel @ 4 ohms with the same footprint as the focal amp. I'm all in!!
I presently run two JL 600/6 amps. That's it. My JL's are only 75 watts per channel though. To get 200 watts I have to bridge em. But technically I can only bridge 3 speakers. Lol!!
  #237
Old 01-03-2018 | 12:28 PM
wuneyewilly's Avatar
wuneyewilly
Gann...are both those 600/6's in your fairing? Would two FDPs fit in an 09 FLHTCU?
I'm thinking about PA601s in the lower pods, PRV 6MR500-NDYs in upper fairing, and not sure about the pak pods. I have stock 5.25 pak pods and havent researched if I can enlarge the hole to accommodate PA601s, or just go with BT747s.
Eventually I'm thinking SBD CCK lids...down the road a bit.
  #238
Old 01-03-2018 | 03:37 PM
marcodarq's Avatar
marcodarq
601's with a 1/2 spacer ring will work. done it.
m
ps when an amp like that comes out i want it too!!!
  #239
Old 01-03-2018 | 04:33 PM
wuneyewilly
Are you happy with the sound being such a small enclosure? What grills did you go with after shimming them out 1/2"?
Poly fill a bit? ...or maybe there is already, havent opened mine yet.
What else are you running?
  #240
Old 01-03-2018 | 06:06 PM
twspalm's Avatar
twspalm
Originally Posted by twspalm
I will follow up as things progress. The Focal Factory (Orca) tech guy is on vacation till the 3rd so nada from them yet. The BT355s arrived just a few days after I ordered them... pretty quick. Don’t know the status of the replacement amp yet... so holding off on taking the fairing off for the third time...
Just got the replacement amp from Pacific Stereo. Simple RMA process from them so I’m going to endorse them as a great source so far. I originally got the Amp with a 25% off coupon code so the price was right too! Nothing from the Focal tech guy so far but I’ll start the diagnosis and new amp install Saturday morning. Should have a report by late afternoon... thinking about doing an install “lessons learned” with pictures and a list of the stuff I actually used out of all the supplies I bought ( ha ha)...
Quick Reply: New FOCAL Fairing amp 4x175w!
