Boom! Box 6.5GT EQ Curves - Key-On/Running
Old 10-06-2017, 02:19 PM
Respect's Avatar
Respect
Respect is offline
I have a lot of questions but the first that came to mind, which sounds better running or off?
Old 10-06-2017, 08:06 PM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,635 Likes on 1,180 Posts
Off sounds much better. It's like you had the speakers covered up with something then uncovered them.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 10-07-2017, 03:31 PM
tesnevo's Avatar
tesnevo
tesnevo is offline
Tuned correctly ON sounds better, but OEM setup sounds like **** on/off.
Old 04-25-2018, 02:50 PM
DE-Glide's Avatar
DE-Glide
DE-Glide is offline
I'm also running the old dealer flash that you can't get any more... 8 speakers, 2 amps, amps off. And there is a considerable difference in EQ between running and not running. I'm sure you can attribute some of it to increased voltage while running, but there is a huge spike in the 90-100Hz range while running. This is what pushed me to getting an Arc Audio PSM DSP and setting up different EQ presets for running vs non-running. I simply have a switch to go between the settings, but other have wired it up so that it automatically defaults to the "Running EQ Preset" when the bike is "ON" position vs the "Accessory" position.
Old 04-25-2018, 05:08 PM
Stew_FL's Avatar
Stew_FL
Stew_FL is offline
Originally Posted by Respect
I've read a bunch of posts about 'Key-On' vs 'Running' EQ curves. Working with JL Audio and one of their TwK88 boxes it seemed like a good time to dig into it. The RTA snapshots below are right off the high-level output (no LOC - that's another bunch of tests I've done and boy is it a doozy). These are just basic Pink Noise tests and I offer them up for sheets and goggles for those who are curious as this is what I do. I'm determined to help get the best out of these systems.
Over-all not much of a difference in curves whether it's in running or accessory position. I see more of a volume curve issue (which is going to be a compromise to fix).
Your mileage may vary, this is based on a 2017 unit running v1.20.3
And for kicks here's the highest volume without clipping (which was full minus one 'bar')
Guess I'll return the RTA I just ordered. You stole my idea. Now if you can check it at speed with and without the AVC. That sure does not llook like this one.
Also what freq is that big spike at the low end before the dip of your pics. I was also going to check if the voltage from the HU went up with the bike moving.
Old 04-25-2018, 05:21 PM
Stew_FL's Avatar
Stew_FL
Stew_FL is offline
Never mind the spike question. Looks like there is a voltage drop across all with the bike running
Old 04-26-2018, 07:33 AM
Respect's Avatar
Respect
Respect is offline
It's not a spike its the SUM.
Old 04-26-2018, 08:19 AM
Stew_FL's Avatar
Stew_FL
Stew_FL is offline
Ya I figured that out after looking at it on the computer instead of my phone. Thats why I said forget the spike question in my post after the original question.
Another question if I may. How were you taking the readings? Directly off the head unit, off the amp outputs, or mic in front of the speakers? And was that AVC on or off?
Everyone talks about the big EQ problem.Thats pretty close to flat other then the low freq drop off at 100h compaired to the 14 map I posted. Maybe the 17s are different.
There is a better bass responce with the bike off though on full and 3/4 vol.
Old 04-26-2018, 09:57 AM
Respect's Avatar
Respect
Respect is offline
These are line signal measurements directly out of the HU, the only way to get an honest picture of what's going on. Soruce was USB 0db tones or noise.
Contrary to many comments I've read, there isn't a noticeable difference between key-on vs running, that was the point of this exercise. But there is a big difference between versions.
I dont' use AVC and never would. The volume EQ'ing is bad enough. In discussing with JL Audio we spit-balled an idea to manage that but I don't think its going to take off.
Peter Quinn
Milwaukee Eight (M8)
02-26-2020 02:12 PM
! rock103 !
2014-2023 Touring Models
78
03-01-2016 04:11 PM
NDBadlands4-2
08-13-2013 03:05 PM
MADDOG187
04-13-2012 03:35 PM
Quick Reply: Boom! Box 6.5GT EQ Curves - Key-On/Running
