Radio interference.
Radio interference.
I have a 2010 Ultra Classic with a stock Harmon Kardon unit. When the ignition switch in the "accessory" position a radio station will come in nearly crystal clear, If i move it to the "Run" position the same station will become very staticy even after the fuel pump turns off. I have played with the high beams and spot lights turning them on and off and it doesn't make a difference. Does anyone have any ideas as to what is causing it and what to do about it?
For all of you that are having this issue due to LED headlights, you might want to install something like this: http://www.ebay.com/itm/121732318755...84.m1436.l2649
That should eliminate your troubles.
GarBare
Electrical/Lighting/Alarm
12-21-2017 06:07 AM
GarBare
Audio Systems
11-18-2017 11:01 PM
