Installing Soundstream Amp in an Ultra
I have 2013 Ultra. I upgraded the front and rear speakers and now it's time to install an amp. I have a Soundstream PN4.520D 4 channel amp.
Reading other posts I think I should use a PAK-SNI 35 line converter, but I think I need two of them. One for the front speakers and one for the rear speakers. Is this the way to go, or is there a better way.
I have the 10 gauge power wire to the battery, and I believe it should have a fuse near the battery, but I don't know what size of fuse.
And I have 16 gauge speaker wire. Anything else?
If there are any posts here I should read or videos on YouTube for this I can't find them.
Thanks for any help on this.
P.S. A 40 amp fuse is sufficient with the 520.D
I think the HK radio is just fine for me.
The bike has Titan II 6.5" speakers in the front and Infinity 62.11I speakers in the rear.
What does "two LL's " mean? And what's wrong with 10 gauge wire for the power cable?
How much power does this amp use???? How big a fuse does it need? The back of the unit has a 40 amp fuse. Isn't that enough for the power wire?
Is it going to burn up my stock charging system and battery????
Maybe the stock HK unit by itself is good enough. I don't want to have to pull a trailer full of batteries for this to work.
You would be money ahead to get an aftermarket HU and run low level inputs with that amp. Running high level with the line levelers is doable but that amp sounds better IMO running RCA's. But to answer your question. Yes you would need two LL's 8 gauge power and ground to the battery and 16 gauge speaker wire. Just out of curiosity. What speakers are you running?
But Gann u said low levels was best for that amp.
Is it also true with the 350 because I was told when I installed mine that the SS 350 as well as RF300 sounded better on high levels.
Just curious cuz I went high but may add some rcas if it's a better route.
Again sorry OP.
My apologies for high jacking .
Again sorry OP.
Again sorry OP.
To sum it up. If you have an aftermarket radio run RCA's. If your running the stock radio go HL and LL's.
Babyboy
Audio Systems
10-28-2015 07:22 PM
