Aquatic Av/SS amp/ Kappa 62.11i install help
2012 FLHTK ultra limited 4 speakers (2 in fairing and 2 in rear pods)
Infinity: Kappa 62.11i
Aquatic AV: AQ-MP-5BT-H
Soundstream: PN4.520D
Hi, I want to apologize if I am not following any of the forum rules, and also want to say thank you in advance for any advice that I receive.I am not much good at this forum thing! Been reading Ultranutz threads and it has been very helpful.
I have pretty much installed the system but have a few questions.
1) If I use the one set of RCA jacks from the Aquatic AV: AQ-MP-5BT-H and use a RCA Y to the Soundstream: PN4.520D, will I loose the fader option on the head unit?
2) When wrapping the speakers with the polyfill, should I pack it into the back of the speaker right up to the cone or just around the outer rear part of the speakers.
3)My most important questions is.... when I turn the stereo on with volume at zero I hear a buzz/hum ( without bike running). I am guessing it is a grounding issue but would like feedback on how to eliminate this.
4)Could someone please post a link on how to adjust and have the settings right on the amp? Should I have switch set to full? What's the best settings for the gain?
1. turn gains on amp all the way down
2. set bass and treble on radio to middle positions (flat)
3. drop in a good acoustical/dynamic CD or MP3
4. turn volume up on radio until you hear distortion while music is playing then back it down a bit.
5. now turn gains on amp up until you hear distortion and then back it down a bit.
6. rinse and repeat for rear channel.
if you're dealing with a 4 channel amp: I unplug the rear, set the front, unplug the front, set the rear, then plug it all back in. It will be difficult to set with all 4 channels plugged in at the same time.
The following 2 users liked this post by UltraNutZ:
AlexTheItalian (11-11-2017),
neub72 (09-10-2017)
Thank you very much for taking the time to respond. I will be trying to get it finished up and back together today and I will be following your reply to the tee! I will update you on my results. Opps forgot that Amazon will be delivering my RCA adapters Tue. I will get done what I can today.
[QUOTE=UltraNutZ;16618668]Yes you will.
The fairing speakers you want to wrap up to look like a cocoon. - https://www.dropbox.com/s/0p7vo8io7i...01141.JPG?dl=0. The lower and rear pod speakers you want to simply line the inside of the pod with a thin layer.
Great picture!! I'm thinking to make the same set on my 2013 Limited, Aquatic + Soundstream PN4.1000D
Could you help me explaining how you wire the system from Acquatic+amp+speakers?
Thanks a lot
A
Thanks a lot
A
Cowboy Rob
02-24-2012 07:29 PM
