When I read your post make think if you simply use rear speaker output and not y of front and don't have a dealer flash rears are dead.i
if you used rear factory then I would use line levler on both .dose your fade work ?
Figured out the no sound issue. I'm just using one line leveler so I had to split it. Works like a champ now and sounds oh so good. The magnets are a pain but I'll get used to it. The sound offsets the negative of magnets hitting.
i read on here about someone shimming one side of the speaker away from the lid to gain clearance. Either way congrats on figuring it out
