I have questions on rear speakers
PRV Subs
Rick,
We're down in Miami and I'd say we are as good as any shop in the country in some parking lot bikes that can be heard on the road. Check out some of our youtube vids. We mostly put 10's in a bags and find if put them up front enough 1. you save some space in the back of the bag (especially stretched bags) 2. you can still feel the bass while you ride. Up front we run pro audio speakers and horns. Come on down, or send us your bags!
https://www.youtube.com/channel/UCIW...98GRrX0A5cnmXA
Which PRV is that in the photo? I have read on here that 10'' subs will require a lot of amp to push them. Is that true and if so would a second battery be required ? I read above that I wouldn't need a second one just for adding a second amp like the JL600/4. Would the JL600/4 be enough for the 10" PRV shown?
Thanks
Rick
One more question,
Will these PRV 10" play nicely with my existing speakers? (BT 7.1 in Front Fairing and Hertz HCX 165 in the lowers powered by a BT4180). My plan was to add another amp ,perhaps the JL600/4 for the rear subs mounted in the bags. And at some point down the road maybe add something in the lids off of the 600/4.
Sorry to be a pain, but I want to pull the trigger on this amp and some kind of speaker set up in the rear.
I have just installed a Razor tour pack , Could the 10's be mounted inside of it facing downward. That way I could drill holes in the bottom of it and I would not have to worry about rain entering it.
