New Aquatic Stereo Install
Hey folks,
Was wondering if I could get some assistance, I just purchased a new Aquatic AV AQ-MP-5UBT-HS and was wondering if anyone here has already installed it. I have a 2012 Electra Glide Classic and have never installed a radio in anything before, I know the company claims it to be Plug n' play but I have seen the wiring and know that you have to do some wiring. Can anyone explain how to wire up the power and speakers, as i know the handle bar controller has a harness that just plugs right in.
The radio is being delivered today, I'd like to install it tomorrow. Could really use the help folks.
thanks in advance
thanks in advance
It is completely plug n play unless you want your rear speakers to work, in which case there are 4 wires that have to be spliced into the harness. The instructions are very clear as to which wires those are. They are green, green with white stripe, purple and purple with white stripe. Those wires are in the harness you don't use (14 pin IIRC).
Hardest part is the 4 bolts holding the unit in place. Luckily I had a set of long allen wrenches with ball ends on them. Saved the day. I'm very happy with the sound and the Bluetooth. Some people would have liked to be able to choose play lists but I just set my iPhone to random. If I don't like a song I can switch to the next using the handlebar controls.
I've seen some complaints about not being able to see the display in the sunlight. I have purposely ridden with the sun at my back and I could see the display just fine. I have the less expensive unit ($300) without Sirius and some other stuff that I didn't need. Instead of a slide out phone holder, there's a big open area. I can set my iPhone 6s with it's Otter Box inside with all the cables hooked up. It's a tight fit, but it works fine.
My install was a bit different since I have a HogTunes 40.4 amp. But it was just a matter of unplugging the cables to it, pulling it off the HK unit and then putting it all back together after the Aquatics was installed. I too have no rear speakers since I have a Streetglide. But I have the HogTune fairing speakers, tweeter pod and 7" speakers in the lowers. I'm sure I won't win any contests with the super systems that a lot of guys in this section have, but it's plenty loud for me even on the superslab.
