Help-adding rear speakers with stock HU
I am looking for some guidance/confirmation.
I have a '98 Electra Glide Classic with a stock head unit. I have replaced my front speakers with 6.5" Kenwoods (can't remember the models) with adapters. They are 2 ohm, I have been running them for a couple years now.
I have acquired some rear speaker pods, minus the controls, and I want to add them so I can give the Mrs. a little bit of sound back there.
Note: I do not have the money to go with a full blown audio upgrade at this time, so getting the rear speakers functional is my only concern for now.
After reading through the site here and trying to figure out a harness to get them hooked up, I came across the idea of just running new wires, in parallel with the front speakers.
If I get 2 ohm rear speakers I can run positive from my front speaker on the same side to positive on the rear and same for the negatives?
Is this correct?
Is this correct?
Are you sure those Kenwoods are 2 ohms? I went through every speaker kenwood had many moons ago and I can't remember any that were two ohms? I must have missed those. Anyway, Are there speakers in the rear pods now? Do you have an amp? Full blown audio doesn't have to be expensive. You can get great sound on that bike for $200 bucks.
This amp:
and these speakers in the rear:
https://www.sonicelectronix.com/item...xoCi1oQAvD_BwE
This amp:
My question is this, isn't this stock system 8ohm? If so I can't see how you haven't damaged the head unit running those speakers. And the answer is no, you can't just simply tie into the speakers like that with another set for the rear. I like Ganns suggestion. Easy upgrade without breaking the bank.
I will get speaker models for you and double check ohms.
No amp.
Does not have existing rear speakers (the Classics did not come with them).
"And the answer is no, you can just simply tie into the speakers like that with another set for the rear."
Should the bold word be "can" or "can't"?
If I can easily mount the pods and hook up rear speakers, that is my goal at this point. I am very budget limited for this.
No amp.
Yes the word should've been can't. If I'm correct and your system is an 8ohm system the 4ohm speakers are doing damage to your head unit and I'm assuming you're still using the stock head unit. If you "tie" in another set of 4ohm speakers like you were suggesting, you then will have a 2ohm load which will do further damage.
No amp.
No amp.
She would hear your tunes much better if you had an amp in the fairing with some decent speakers like the Infinity Kappa 62.11i's. Trust me bro. My bike is loud as hell. But when I ride with the OL she totally blocks the rear pod speakers and she can't hear em. All she hears are the lids and the fairing speakers. We've had that conversation many times!
Up to you as to which way you want to go but IMO your money would be better spent throwing an amp in the fairing. If you want to continue your quest for rear speakers we will help you get there but I'm telling you it's a dead horse.
Understood.
I will pull my fairing off one evening this week when I can get over to where I keep the bike and double-check the ohm situation. I thought when I got the speakers they matched my head unit, but its been a while so I'll look.
Will report back when I have more info for you guys.
I really appreciate the help.
Understood.
