PN1000.D Clipping at extremely low gain settings
17 Limited
I bought a SS 1000d amp and the PRV 200s from a member here and installed it last week and used the stock speakers for a week. The amp definitely woke up the stock speakers for sure and I had zero problems.
I ordered a set of 62.11 Kappas for the fairing and while I was waiting I decided to mount the PRVs in the rear pods, zero issues.
The Kappas showed up and I installed them last night.
I went on a ride with some friends today and it was quite embarrassing. The amp was clipping and I had to turn down the volume so low to stop the clipping that I just shut the radio off. Then the wife starts bitching because she had no music, which made for a miserable trip.
I came home removed the fairing to see if something was a miss like loose wire etc. Everything was tight so I loaded a song that was clipping earlier (Tom Petty Don't do me like that) hardly a song that should pull more juice. I have to set the gain at around 9:00 to keep it from clipping, and this is all by ear so far.
Why is this happening?
It was fine with stock speakers for a week. Could it be the new speakers need more power? Could it be I bought someone's junk? It's not like it was at a deep discount and nothing was mentioned.
By eye and ear where should the gain be with Kappas? I have read around 10:00 is a good start.
When you say clipping you mean it was shutting off on you?
Gains are determined by the input voltage to the amp, there is no eyeballing it as input from one unit, LOC, line leveler, etc. is all different. Check your wiring, post pics of it. An amp can clip (turn off) for numerous reasons. Distortion, lack of power, wires or RCA's touching metal, faulty speaker, etc.
I understand gains are set with meters. I don't have test tones or a meter yet so I was doing it by ear for the time being.
All wires are new and all connections were checked. The only difference being new speakers added. I will post pics shortly
That amp benches at 237 watts per channel at 2 ohms. With the volume at 3/4 and a 1000Hz test tone treble and bass flat. Your target voltage on the Kappa's should be around 21 Vac. The amp is rated at 140 watts per channel with 4 ohm speakers. Target voltage with the PRV's should be about 23-24.5 Vac. Those numbers will get you in the ball park. Sounds like the gains are not set properly IMO.
Old Rust (07-29-2017)
The gains we're backed down to stop the clipping by ear. Now the volume is so low I can't even hear it at speed. Meter or not something is not right
Slap the old speakers back in and see if you're still cutting out. 10 minute job. If the old speakers aren't clipping. There's an issue with the new speakers. If the old speakers are clipping. It all points back to the amp set up i.e., Gains, RCA's and Power to the amp.
In regard to your BT Line leveler. I've never had to adjust anything on the line leveler to get good sound. Unless of course the line leveler is defective. Also a possibility but you have to eliminate all the other variables before you draw that conclusion.
