Basic system upgrade, thoughts?
Old 08-01-2017, 09:38 AM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,541 Likes on 2,146 Posts
Originally Posted by Sturgis67
Why does he need a splitter, he only has 2 speakers?
edit: oops, already covered.
Oh, and by the way, those Infiniti speakers should work fine with that SV amp.
Thanks. Because I'm a lunatic and am paranoid about the water resistance of the Kappa's, I picked up a pair of Polk MM652 marine rated speakers.
Amazon has a great return policy, so I figure I'll try them both and see which I like better. Hopefully the Polks - I'd rather not to have to mask off the grilles when I wash the bike.
Old 08-01-2017, 09:46 AM
dunez's Avatar
dunez
dunez is offline
2nd Gear
Im using Polk MM652 with JL MX280\4 amp and a JL FIX86 in my fairing of my 15 RGS. Sounds great I had a BT355 sounded great with the bike off but the sound was lacking when the bike was running
Old 08-01-2017, 10:07 AM
Sturgis67's Avatar
Sturgis67
Sturgis67 is offline
I've heard real good things about those new Polks!
let us know what you think.
Old 08-01-2017, 11:12 AM
Mchad's Avatar
Mchad
Mchad is offline
Can you elaborate on this? I see nothing but good things about the 355. I do know that HD changes the output based on run/stop so this makes sense. Did you go a different direction?
I will for sure.
Old 08-01-2017, 11:23 AM
dunez's Avatar
dunez
dunez is offline
2nd Gear
Yes the radio has 2 different outputs. with the LL it sounded great when the bike wasnt running but once running it sounded really flat, I ended up taking the BT355 out and replaced it with a JL FIX86 calibrated it using the sound track supplied. Sounds so much better.
http://www.jlaudio.com/fix-86-car-au...m-tuning-98103
Old 08-01-2017, 05:03 PM
Mchad's Avatar
Mchad
Mchad is offline
Thanks for the info. But, OUCH! $379 is a bit steep. I'll give the BT a try I think.
Old 08-04-2017, 02:35 PM
huntingnut's Avatar
huntingnut
huntingnut is offline
I'm thinking of doing a similar build on a friends '11 RG. Do the pre-Rushmore bikes use a line leveler? Is the wiring different for a HK head unit to the amp?
Old 08-04-2017, 02:45 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,239 Likes on 1,002 Posts
On a PreRushmore you'll use a Line Out Converter (LOC) instead of a Line Leveler.
PAC SNI 35 is what you want.
ScottBrosRacing
Audio Systems
21
05-09-2019 10:45 PM
vhmike73
Audio Systems
02-23-2013 09:39 AM
flhxmc
Audio Systems
12-12-2012 03:43 PM
2067
06-10-2012 08:18 PM
Mixter
08-14-2011 04:16 PM
Quick Reply: Basic system upgrade, thoughts?
